Mystery
"Octals?"
Yes.... the larger glass tubes with the larger bases and up to 8 pins. Neither schematic that David just sent can be it...the one has 7-pin miniature tubes....the other has SIX octals...yours only has 5.   Icon_wtf
Hold the presses!
The "miniature" schematic also has octals listed below the miniature numbers.....never seen that before....so it might be your schmatic.
Jake take a look at the Hallicrafters series S-38D an S-38E  8pin vs 7pin tubes . the cabinets are different but the only real difference under the hood are the tubes. Marketing at its finest!! Have a Happy New Year.
"Jake take a look. . . "
Yes sir!   Icon_idea
Thank you Richard.R3Sons — 01:37 AM
R3Sons, I buy my resistors from either digi key or mouser ! Sincerely Richardradiorich — 01:28 AM
Replicating (dogbone) resistors what method have you used ?
Hello Guys, Ican't wait to try printing some of these I might go ahead and order some from PCB way ! Sincerely Richa...radiorich — 01:26 AM
Does anybody have a line on replacement resistors?R3Sons — 12:21 AM
42-345 Resistors
I replaced all the electrolytic capacitors. That big Philco 12uf 400V electrolytic Vienna sausage. is one I removed and ...proftrussell — 11:58 PM
Well...taht's a start.morzh — 10:15 PM
X6 is out. Only pulling 3mA now, 220mA with the light on. Test point 18 is 12.2 Test point 19 is 12.06R3Sons — 09:46 PM
Philco 7053
Any of you guys have and used this tester?Martinj — 09:27 PM
I would test all, but the X6 is the main suspect. The output is the autotransformer, and it also could potentially ha...morzh — 09:13 PM
Yes, I tested them out of the circuits. I posted my measurements where the first letter was red and the second was blac...R3Sons — 08:52 PM
