A silent 1928 Philco 511
Hello,
I just joined the Philco Phorum.  as an avid antique radio enthusiast ,I have always been impressed with the quality of Philco information. Some years ago, I found a Philco 511-tabletop (circa 1928.). In addition , I have several other Philco radios as well, and ,again, have been impressed with the tech data available. But, unfortunately, it must not have been available in the late 20's---or at least I have not found it! I am retired now and have more time to work on radios.
I have spent time doing some basic cleaning,tube testing, and trouble shooting. The 511 just stares back--All the tubes checked good and the filaments are glowing. Also I seem to have all the basic voltages from the transformer,as shown on the Rider sheet. The radio remains silent.  I do note that B+ is missing-hence the silence-I have checked the voltage divider--resistances seem in tolerance---BUT missing the 70K ohm  resistor. I question the condenser pack also. On this unit, none of the transformer or condenser terminals are numbered.
Is there more complete data available?
Also--what is the LOC terminal and how is it interconnected ? An antenna and ground were connected.
Any suggestions ?
Thank you!
Welcome to the Phorum!
Icon_wave
Just to start off...have you seen the annotated schematic that is in the Philco Library?
And the Wiring Diagram from the 1928-1936 Wiring Diagram booklet also in the library?
Some of the more knowledgeable folks will likely chime in with some ideas for you.
Hi Bud and Welcome,
Give this a try https://philcoradio.com/library/index.ph...chematics/ Click on 511. If #70 is missing you should be able apply an audio signal to #24 and hear the signal thru the speaker if all is well. 70 provides the hv to the 27 tube which is the detector. That's why for now the set isn't receiving, there maybe other issues. Would go through and check all of the pin 2's of the 26's to see if you have hv there. In good working order about 135v of lower the bypass cap connected to it is leaky. If 0 the coil is open and will require a rewind.
Terry,
Many thanks for your suggestion. I did try that at #24, but no luck. Kept troubleshooting--ultimately found an open choke #36( 1 0f 2) in the power supply. Tested by bypassing with 2--1K resistors,in parallel=500 ohms-across the open---worked! Finally have HV (B+).  Finally able to listen. Speaker was missing,but substituted with a high impedance Crosley speaker. That "LOC" terminal was connected to the antenna input--acts as an antenna.
Radio now works!
Bud
Nice information!
Thank you.
Icon_lol
Don't know if I'd fool w/the LOC connection. If 35 is leaky or shorted it could burn up the primary of the ant coil. Connecting the ant to the ac line even thru a small cap is going to couple whatever electrical noise that's around to your set. Could give lots of noise and interference. When you rebuild the filter can (that's where 35 is hiding) I'd reduce the value down to .001 or .005 mf 630v you could leave it out completely.
My old model 87 has it w/a new cap in it @.005 it sparks a bit when connecting the LOC to the ant post. Same set w/a bigger p/s and audio stages.
Canadian GE Model 41
Umm....you do not clean potentiometers with contact cleaner. Unless cleaning the carbon layer of the base is the goal. Y...morzh — 05:52 PM
I got the tube tested and it was TU. I have installed a replacement tube. During this last effort I discovered part of...Mtmattking — 04:01 PM
Restoring Philco 96
I opened up and lubed the volume pot. It is suposed to be 500K (no one expects it to be that), and it is about 1.5M. T...morzh — 03:34 PM
Compatible crts
The 5JP1 sounds like either like a military tube, or one built for some piece of older industrial equipment.Arran — 02:59 PM
Thank you morzh. I will try that today.R3Sons — 02:06 PM
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
There are currently 2198 online users. [Complete List]
» 1 Member(s) | 2197 Guest(s)
