heath IG-102
hi, this sig gen is not working on band E and F. I've changed some out of spec resistors. can't get e & f to work.
Try another 12AT7 and clean the band switch.
Eico 232 VTVM Schematic
There are currently 9049 online users. [Complete List]
» 1 Member(s) | 9048 Guest(s)
