Today's find. 40-205
Found this today for.  After a quick dusting and a little Olde English, she doesn't look half bad.  IT plays too.  I know, I know.....I will get it restored. But when I went to pick it up, they had it playing. It sounded great, with lots of volume, and good tone. Picked up a ton of stations, unlike some of my other radios.
Its a 40-205xx.  Not sure of the proper suffix letters.  I think this might be the one that took the wireless remote. Not sure.
I'm kind of on a roll this week.
[Image: https://i.imgur.com/zj4LTWE.jpg]
[Image: https://i.imgur.com/faKv0nB.jpg?1]
[Image: https://i.imgur.com/6mJPp4x.jpg]
[Image: https://i.imgur.com/zGJkILB.jpg]
You've have the radio bug, take 2 tubes and call the radio doctor in the morning. Paul
Oooh,
That is pretty! It even has the indicator jewel still...
Vey nice
Kirk
Nice looking...
Anybody here own one? The volume is locked on this one. I think it has something to do with the Mystery Control setup. There is a little prong that sticks out and doesn't let the volume dial move more than a 1/4 inch or so. I can see that if it wasn't sticking out, the dial would spin freely. I can't get it to move out of the way.
[Image: https://i.imgur.com/ddMEvDD.jpg?1]
Ok follks.....REVELATION TIME!!!!!!
The volume wheel is just an up and down SWITCH!!!!  I was expecting it to be a rheostat with a lot of movement, but it just goes UP a little bit and DOWN a little bit, to make contact with what is seen in my photo. That prong sticking out is what moves it up and down a little bit to make contact.  I needed to WAIT for the motor to turn the volume up or down.  AND I wondered how you turn it off because there's no on off switch.  Guess what?  I hold DOWN on the wheel until the volume goes all the way off, and them wait a few seconds, and the power is turned off.  SO there is nothing wrong with the volume switch, it was just OPERATOR ERROR.
Nice radio. It looks in really good shape. Nice find! Thanks for sharing.
The power volume control uses a 2 ph motor. By exchanging the motor condenser connections the rotation changes, that is what the up/down volume control does.
Outside of other possible mechanical issues, the condenser for the motor usually dries up so no rotation or very little torque...
It is a non-polarized but I have used two regular electrolytics back to back, doubles the voltage rating and halves the mf rating...
If there is a large, open wire loop at the bottom of the cabinet, that is the receive antenna for the wireless remote...
YMMV
Chas
Pliny the younger
Philco 7053
Thread moved to test equipment section. (I have not used one of these)klondike98 — 07:05 AM
Thank you Richard.R3Sons — 01:37 AM
R3Sons, I buy my resistors from either digi key or mouser ! Sincerely Richardradiorich — 01:28 AM
Replicating (dogbone) resistors what method have you used ?
Hello Guys, I can't wait to try printing some of these I might go ahead and order some from PCB way ! Sincerely Richardradiorich — 01:26 AM
Does anybody have a line on replacement resistors?R3Sons — 12:21 AM
42-345 Resistors
I replaced all the electrolytic capacitors. That big Philco 12uf 400V electrolytic Vienna sausage. is one I removed and ...proftrussell — 11:58 PM
Well...taht's a start.morzh — 10:15 PM
X6 is out. Only pulling 3mA now, 220mA with the light on. Test point 18 is 12.2 Test point 19 is 12.06R3Sons — 09:46 PM
Philco 7053
Any of you guys have and used this tester?Martinj — 09:27 PM
I would test all, but the X6 is the main suspect. The output is the autotransformer, and it also could potentially ha...morzh — 09:13 PM
There are currently 2345 online users. [Complete List]
» 1 Member(s) | 2344 Guest(s)
