Heathkit SG-8 RF signal generator
Hello all.  Brought home a signal generator in need of some attention.  Replacing the caps and resistors is simple, but I have questions regarding the selenium rectifier.  Has anyone re-built one of these units?  What should I replace the selenium rectifier with?  All help greatly appreciated.  Take care, Gary
I have not done one but here is a reference to a how-to publication:
http://www.w3hwj.com/index_files/RBSelenium2.pdf
Thanks, Bob. Interesting reading.  Take care, Gary
There are currently 9286 online users. [Complete List]
» 3 Member(s) | 9283 Guest(s)
