I have it now
It came in today.
It was listed as a 52 and it looked like one
in the pic's. But when I open it up to check tubes
and thinks before powering it up I started to wonder.
What do you think. is it the right chassis? Just looking for
some good info this is the oldest radio I have gotten.
I will let you know it is working great.
VERY interesting, and puzzling. The label is obviously correct. It must be a model 56, although I cannot find this model in the gallery, nor find its schematic on Nostalgia Air, nor does a Duck-Duck-Go search produce any real information about this model. I defer to our Phorum experts. Perhaps they can shed light on this question. I'm intrigued. I have a feeling this must be a fairly rare model. I'm going to keep an eye on this thread.
Model 56 was made for export to the UK. There is no USA documentation since it was not intended to be sold in the USA.
Guess what.... I just purchased a big pile of Philco UK service bulletins. truePhilco - I'm pretty I've got the docs on this model. Icon_smile
The authors image of the tube lineup gives a clue, not tubes, but Valves.
Certainly looks like it has been serviced in recent times, the transformer with "pvc" lead-wires. Possibly a conversion from 220 ac to 120 ac?
Chas
Pliny the younger
This is on the side of the tube sheild
Second clue is the 42 "valve" in the picture. In small print "made in England." Take care, Gary
and the tubes behind the shield have been changed
There was one of these sets on the Phorum maybe a yr or so ago... I think the poster was in the UK.
Here's a quick scan of the service bulletin for the UK Model 56:
You all are something, Thanks.
I found a couple of post on the Phorum of the 56.
Have the bulletin, Thanks
Kind of sad I thought I was going to have a 52B.
haven't seen a date for a 56 I guess 1932.
It came from California and said it wasn't working.
But its working now, after adjusting and lubing the band switch.
[b]Philco[/b] in the [b]United[/b] [b]Kingdom[/b] [b]Philco[/b] began exporting Model 20 Baby Grands as well as other models to the [b]UK[/b] in 1930. [b]Philco[/b] continued to export Philadelphia-made radios to [b]Britain[/b] until 1932, at which time a new subsidiary was formed – [b]Philco[/b] Radio & Television Corporation of Great [b]Britain[/b].
Philco in the United KingdomPhilco Library
philcoradio.com/library/index.php/philco-history/philco-around-the-world/philco-in-the-united-kin…
Now That makes this radio seam really nice! It was exported and
it came back an its made in the USA. COOL  Icon_biggrin
Here some more Info
I have to find a phonograph the same year for I've notice
the plug in for it. Icon_smile
UK power is 50HZ so if you use a step up transformer to get from 120 volts to 240 volts the motor will run to fast so you would need a motor for 60HZ.
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
