new guy seeking assistance
I was just getting ready to post the photos but see you have been successful!
Yup. Now I have a new problem. I bought it. It has two issues. And I don’t know much about this stuff, so forgive my naivety.
The -what I would call the “tensioner” wheel on the turntable has a tiny flat spot on the edge, so it kinda sounds like a metronome in the background when playing a record. Is there a replacement part for something like that?
The other is that can’t get much volume out of the unit at all right now, no sound at all out of the subwoofer, I obviously checked the wiring, but couldn’t find anything suspect.
So I’m assuming something in the amplifier? All the tubes are lit up, but does that mean they’re all functional?
Hello, check here for a new idler wheel. I've used them for different wheels over the years. They also sell needles and cartridges.
Gary is a good guy to deal with and will help you out.
https://www.thevoiceofmusic.com/
My best guess for low volume and somethings not working well is that the power supplies is dying do to bad filter cap and bypass cap throughout the tuner and amp chassis. If you continue to operate it in this condition it can damage expensive parts and worst case catch fire. Servicing this set is somewhat of a fairly large undertaking as there are probably 20-30 caps to replace some resistors and an alignment to do afterwards. I'm not sure what your skill level is for this sort of thing is but wouldn't catogorize it as an entree level project. No ofence just being honest. You might luck out and may have mostly disk caps rather than the older foil/paper style.
GL.
Thanks for the info. My skill level is not advanced. How much would I pay someone to do something like that? Ballpark?
Don't really know. Depends on who working on it. If there is a radio club, old or ham perhaps there is someone there that is willing to take it on. I would think that this would be more economical that a shop. The flip side is that hobbyist may not be in any hurry to get er done.
There is a Wisconsin Antique Radio Club where you might find someone relatively close to you to work on the set.
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
There are currently 3839 online users. [Complete List]
» 1 Member(s) | 3838 Guest(s)
