Threads: 8
City: Eau Claire
State, Province, Country: Wisconsin
I am in need of two new type 41 tubes (from a 41-290 Philco). Is this the replacement?
https://www.tubesandmore.com/products/41...e-st-glass
Thanks for the help!
Threads: 268
Yup...
Threads: 114
City: Sneedville, TN
The ST refers to the glass envelope. It means a tubular envelope. It will be a constant diameter all the way from the base up, rather than bulging like a regular 41G. It is a direct replacement despite looking different because of the envelope.
Threads: 36
City: Brandon, SD
I thought ST stood for “shouldered type”, and the GT type was the consistent diameter type? ST and G are the same thing and GT was the later, non-shouldered glass versions?
Threads: 18
City: Kingsville Ohio
Best place I've found to get tubes: findatube.com Bob Dobush has tons of tubes and I checked; 41 new $6.50 used $3.00. Hope this helps.
Dick
Threads: 114
ST is not actually a standard abbreviation. I believe I saw it on only one tube I ordered which was Russian made. G is what you call "shoulder type, GT is the later, smaller, straight side version, and later many GT types are marked GT/G to save confusion, clearly showing it replaces either. Except for looks they are the same , BUT, if there is NO SUFFIX, and the tube has a metal outside, it can be a problem in Philco radios. These metal tubes use the case as an RF shield, and it connects to a pin that is connected to the ground plane of the radio. Philco radios use the G or GT types which do not use this pin, and so use the socket solder lug as a tie point, which can be live, so you can't use a metal tube in Philcos safely, metal does not substitute for a G or GT type. This is why many RCA radios don't use tube shields for their RF, oscillator, and IF tubes, the metal tube IS the shield, but Philcos and other radios use those shields and G or GT tubes.
Threads: 34
City: Elkhart
Quote:Except for looks they are the same , BUT, if there is NO SUFFIX, and the tube has a metal outside, it can be a problem in Philco radios. These metal tubes use the case as an RF shield, and it connects to a pin that is connected to the ground plane of the radio. Philco radios use the G or GT types which do not use this pin, and so use the socket solder lug as a tie point, which can be live, so you can't use a metal tube in Philcos safely, metal does not substitute for a G or GT type. This is why many RCA radios don't use tube shields for their RF, oscillator, and IF tubes, the metal tube IS the shield, but Philcos and other radios use those shields and G or GT tubes.
Hi Mike, does this also apply to Zenith radios as well?
I'm wondering because I have a 1942 Zenith 10S690 Radio that all of the tubes in the radio are of the G type variety of tubes and all of the critical tubes in the set had shields around them, there was one tube in my Zenith that was replaced at one point in time that was replaced with a metal cased tube and the original tube shield was tossed when they installed that metal cased tube into the radio (the radio other than the 6A8 tube and the 5Y4G tube has all of its original Zenith tubes in it yet).
Threads: 114
Pull out the chassis and the metal tube, with the radio unplugged, of course. Then ring out between pin 1 and ground, as well as between pin 1 and the other 7 pins. Pin 1 should either not be connected to anything, or it should be connected to ground. If it is connected any other way, the tube should be a G or GT type, not a metal tube.
(This post was last modified: 02-11-2020, 05:22 AM by mikethedruid.
Edit Reason: spelling
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
