Phico 70 resistors: red-yellow-yellow
Threads: 569
What I am not sure of if these follow the color convention or they don't.
Here's why: they (body-end-dot being RYY) supposed to be 240K which is what Steve's labels on his resistors show if you look in here:
https://www.ebay.com/itm/Reproduction-Do...ect=mobile
However if looking here,
http://www.nostalgiaair.org/Resources/833/M0013833.htm
On page 1-18 in Resistor Data table they show 250,000 ohm.
But on the page 3-32 in the table 4 "resistor data" the same ones are shown as 330,000 ohm.
So.....which one is it?
Threads: 72
City: Linn Creek, MO
It is not just the 240K, if you look at the parts list they show a couple of 50K, but in your chassis you will find 51K. In other Philco radios, 99Ks are used but, the parts list shows them as 100K. At any rate, we are talking about less than one percent difference.
M R Radios C M Tubes
Threads: 72
I just looked at Ron's schematic in the Phourm Library https://philcoradio.com/library/index.ph...chematics/ and it shows 240K.
Threads: 44
City: Roseville, MN
Well gee, if you're going to have a standard why not use it? We all know RYY is 240k and sometimes a production run is short of the correct value. 250k is close enough! ! 330k looks like you can chalk one up for Riders or maybe even Philco.
Rod
Threads: 8
City: S. Dartmouth
State, Province, Country: MA
Now don't put my brains in the fire!
Long ago, in some publication on radio, I had read, that, the Philco production environment used a LOT of mercury lamp illumination. Because the light was so rich in UV, normal color codes could not be used. Thus, odd ball colors.
Given that dog bone resistor drift and production line changes did not always get recorded, we, see the resistors as they are, different.
Dog bones like paper caps are way beyond end of life. I abandoned using measured values of dog bones (re-paints). I found that they continue to drift from the current flow and even moderate heat, have gotten noisy too...
YMMV
Chas
Pliny the younger
(This post was last modified: 02-17-2020, 12:15 PM by Chas.
Edit Reason: Spelling errors
Threads: 569
Believe it or not, most of the resistors in this Philco are within the tolerance.
But these two measure 360K in-circuit or so.
Threads: 72
Quote:But on the page 3-32 in the table 4 "resistor data" the same ones are shown as 330,000 ohm.
3-32 table 4 is for the late version 70
The early Philcos used a proprietary resistor color code. Generally a solid body color and sometimes an end color. The Philco 20 used this system and probably was the last. The Philco 70 and later used the standard BED color code.
Threads: 72
I just pulled out a couple of 70 chassis that I have and checked the resistance of the Red-Yellow-Yellow resistors. One of them they were pretty close at 245K give or take. The other was not so good, one was 410K and 418K.
Threads: 569
So, in 570 how do I know which version of the mentioned ones do I have? I have not found (in Riders or the compilation of it on Nostalgia) the chassis that would be exactly what I have. Either resistors do not agree or the backelite capacitors.
Also......if the rest of the resistors in my radio do use the standard color chart (say Green-black-red is 5.1K, and so do others) then I think indeed my Red-Yellow-Yellow are 240K.
They wouldn't mix the standard/non-standard ones, would they?
Threads: 9
City: Springville NY
State, Province, Country: NY
Morzh,
I don't know if this helps, but I found an old article in Philco News dated September 1931 page 12 that states: "Starting with the Model 46 and continuing in all future models, standard R.M.A. colors are being used to indicate the value of various resistors in Philco Receivers." It continues to list part numbers , color codes and resistor values. I cant up load the page right now. It clearly states that Red body, Yellow tip and Yellow dot is 240k, 1 watt P/N 3768. It also has the same color code for a 1/2 watt P/N 4410.
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
