model 38-10 no reception after recap
Threads: 5
City: Boston
State, Province, Country: MA
Hi all,
I've completed my first overhaul, replaced all capacitors including cans and bakelite block, (except mica), all resistors, new rectifier socket and tube. (this pic taken before I replaced the socket)
The good news is that it did not explode or burn out after powering up. All tubes lit, but I do not have a way to check if they are all good. Bad news is that I get no reception on AM or shortwave. I get a little air through speaker, nothing much else. 10' of 22G wire attached to red antenna terminal. Nothing attached to black.
What are the next steps to sorting this out? Thanks for any help you can lend this beginner.
Threads: 268
Probably the easiest thing to do would be is to do some voltage checks to see if you got voltage where it needs to be. Go over the the 6F6 tube and measure the DC voltage from the chassis to pin 3 of the tube and then measure pin 4. Both pins should have abt 250v or so on them.
Threads: 569
Touch the grid cap of 2nd detector 6q7.
See if you have hum in the speaker.
Threads: 5
City: Boston
Thanks. Pin 3 is settling in at around 283v, pin 4 278v. When I touch a probe to the top of 6Q7 the speaker buzzes. The grid cap is loose (connected to wire, but wobbles) on 6A8.
Threads: 268
Ok so that seems to be in good order. Have a look @ pins 3 and 4 on the 6K7 Should see some hv there too. On the 6A8 pins 3,4, and 6 will have some hv too but will be less on 4 and 6 vs pin 3.
If all that seem reasonable it's time to breakout the signal generator.
You may want to resolder the gridcap oin the 6A8 to be sure it's making a good connection.
Threads: 5
City: Boston
tube 6A8: pin3: 179v pin 4: 68v
tube 6K7: pin 3: 272v pin 4: 67v
tube 6Q7: pin 3: 232v (this one is double what the schematic lists)
tube 6F6: pin 3: 283v pin 4: 266v
tube 6A8: pin 3: 173v pin 4: 67v
Threads: 268
Pin 6 of the 6A8?
Also have a look@ pin 5 should see a little bit of - voltage there with a modern meter.
And are #19 and 26 within tolerance?
(This post was last modified: 02-22-2020, 09:58 PM by Radioroslyn.)
Threads: 5
City: Boston
Threads: 268
Tada! we got it. It seems that either #15 is open or #5 between pins 4 and 3 are open. Which ever you need the 130v or so on the plate pin of the oscillator section of the pentagrid mixer and it's getting lost down by #15.
With the set off measure the resistance across pins 3 and 4 of #5 (oscillator coil). Should see a low resistance like an ohm or so. If not remove the coil and give it a close inspection for rot (green spots) or a break in the wire.
(This post was last modified: 02-22-2020, 10:53 PM by Radioroslyn.)
Threads: 5
City: Boston
Thanks, Terry. Are you referring to #15 resistor and #5 Osc. Transformer? What am I looking for... bad connections to/from either? bad component? Not sure how to rectify this.
Threads: 268
Correct!
You can follow the hv from the bottom end of #15 (5000 ohm resistor) to the top end of 15 then to terminal 4 of the oscillator coil then to terminal 3 of the oscillator coil/pin 6 of the 6A8.
Threads: 268
It would seem that your wire is open from the coil to the tube socket or a bad solder joint where the wire is solder @ the socket. If that is ok pull the 6A8 out and measure pin 6's resistance to the chassis w/the set off. Should see a high resistance like 20 or 30K this eliminates a shorted socket. Measure the voltage @ pin6 w/o the tube in place maybe your tube is shorted.
Threads: 5
City: Boston
Got it! Seems Bad connections at these pins are the culprit. I was able to get 160v to the tube when I moved these a bit, making a connection. Can these be secured/soldered?
I have reception!! not many channels, but a few strong ones on AM and a few weak ones on SW.
This is great, thanks so much, Terry!
Now on to see how I improve reception (and make these connections more stable). Any thoughts welcome!!
Threads: 268
Not sure which connections we are talking about but the coil you can gently scrape the wires at the solder connection and re solder. If it's the tube socket you can use a pair of needle nose pliers and gently pinch the connector on the socket w/o the tube in place. Be careful the metal can be weak and fold easily then your looking at a new socket.
To improve the performance you'll need a signal generator to adjust the IF amplifier and other stages of your set. Something simple is fine just need to verify it's accuracy.
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
