Espey AM/FM Tube Radio Identification
Good morning can anyone help me identify an Espey AM/FM tube radio?
The only identity available is the Espey Branding on the dial glass and An RTMA Code #174 on the tube chassis. There is also a number (possibly a serial) 304067.
It was a replacement or modification for a Philco 42-1012P I recently purchased. My cabinet is beautiful. I love the Philco look. Especially, during the 1940s.
Thank you for any help.
A few pics of the chassis would help sort it.
Good morning,
Thank you for response. I tried to post a picture on the original message. I must have done something wrong. I will try again.
Thank you.  Icon_biggrin
Sure looks like an Epsey model 100 from '52.
Thank you! Thank you!
I will now have some sort of starting point.
I send an update when I have changed the wires, caps, and resistors.
I couldn't find any free info on the Epsey but it is listed in Sam's so could be ordered from them.
Thank you for lead. It will cost $15. Well worth it.
Thank you
There are currently 9891 online users. [Complete List]
» 1 Member(s) | 9890 Guest(s)
