Westinghouse tuning issue
I've just completed electronics restoration of a Westinghouse WR-217. All paper and electrolytic caps have been replaced and all out-of-tolerance resistors replaced. A full alignment using a signal generator has been done. One other notable item is that I had to replace the antenna coil with a tunable universal coil. All voltages are close to stated voltages.
The radio receives plenty of stations BUT the audio is distorted sounding like the tuning is slightly off frequency. No amount of fussing with the tuning cleans up the reception.
Where do I look next? Any suggestions will be greatly appreciated.
Thank you
Don
http://www.nostalgiaair.org/pagesbymodel...024273.pdf
Measure the dc voltage from the chassis - to pin 5 of the 41 tube +. Should see some - voltage there.
Pin 5 of the 41 tube is hardwired to chassis. It shows as connected to ground on the schematic. Is this incorrect???
BTW - grid voltage is -12.7v.
Sorry meant pin 4. Bias looks ok.
Double check R-3,R-8, and C-14. I'm thinking your avc circuit isn't working.
I'm reminded of a Zenith console I was working on several years ago that also had a distortion issue.  After much hair pulling I noticed it used the same speaker as a parts console I had.  On a whim I plugged in the other speaker and BINGO, the distortion was gone (and the offending speaker looked perfect).  It's probably a long-shot, but if you can substitute in another speaker it would rule that out.  Ever since that experience I keep a speaker substitution box in the shop:
Photo courtesy of Steve Johnson: https://stevenjohnson.com/testers-misc.htm
Terry,
The AVC seems to be working properly; varies from -2.5 to -3.5v depending on signal strength.
Now for something unexpected; I knew the resistance element of the original volume control was not smooth and measured ~800K vs correct 500K.
Upon replacement, the distortion disappeared!!??
Thanks for your help.
Another question - do you know of any source for the clear plastic tuning dial cover?
Don
John,
Thanks for the suggestion. The speaker substitution box is a great idea.
Do you know the approximate field coil inductance typical of the 30's radios?
Don
Quote:Another question - do you know of any source for the clear plastic tuning dial cover?
Dialcover.com makes one for the WR-217:
https://dialcover.com/
Don, a lot of the Zeniths I've been working on lately are ~ 1000 ohm field coils.
I picked up the Ferret box about 3 years ago.  Prior to that I used one that has most of the tolex covering peeling off.... looks horrible but it still works fine.
Philco 91 Restore Code ??
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 3178 online users. [Complete List]
» 1 Member(s) | 3177 Guest(s)
