Westinghouse WR-217 Cabinet
Does anyone know the original color of the three strips running around the Westinghouse WR-217 cabinet?
Gold? Yellow? Amber?
Don
Hi Don,
I actually have one of these. The 3 stripes appear to be a very light yellowish brown. It appears that they are painted on, not an inlay. the cabinet is a medium finish (walnut?).
As soon as I figure out how to attach a pic, I will take one and send to you.
Thank you for the input. I was able to closely replicate the original using 1/16 inch gold striping tape.
Bet it looks nice!! Icon_clap
John
I actually looked up that radio and I noticed that some of those WR-217 cabinets had that stripe detail and some didn't, yours may have been one of the ones that didn't come with the stripe detail from the factory.
There are currently 3081 online users. [Complete List]
» 1 Member(s) | 3080 Guest(s)
