1st post.
Howdy,
I’m a rank amateur to this radio hobby. Got my first one just yesterday. I am wondering about the model and vintage of the radio. It works well as does the clock.
It has the number F-228 as well as Part No. 78-3650. Any help is appreciated!
Best regards,
Bob
What brand, any photos? Welcome aboard. Paul
Hi and welcome,
Looks like it's from '58. Well on 2nd thought I'm think it's a bit newer. F would indicate a 1958 production but I can't find anything like it in '58.
http://www.heat.net/store/Antique-Philco...65671.html
So the mugshot matches a P724 from '66 (AA5 set) service info here: http://www.rsp-italy.it/Electronics/Radio Schematics/Collections/Beitman pg 96.
Many thanks!
91H Code 126 Restore
There are currently 5566 online users. [Complete List]
» 1 Member(s) | 5565 Guest(s)
