Threads: 91
City: Jonesboro
State, Province, Country: AR
I'm working on a Model 16, code 125. I've got the smaller 4-section filter cap replaced, the black bakelite tubs restuffed, and I'm working on the main filter caps, a dual 91 and 98.
Someone else worked on this and some things were switched around, and replaced.
The Dual 91 can was original. It has 2 connections on the bottom, and was isolated from the chassis with a cardboard ring. The single cap (I'm assuming 98) had been replaced. The black lead was connected to a tab, which was shoved up between the cardboard and the can of 91.
Is this correct?
I'm replacing the dual and single, and putting all 3 in 1 can to simplify things.
The Question is: Do I have the polarity marked correctly? (Highlighted in pink).
According to the schematic, It doesn't look like the 91 can should be isolated from the chassis. Or is my brain fried?
Any help appreciated.
[Image: https://live.staticflickr.com/65535/4971...e3d5_k.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Threads: 91
City: Jonesboro
I'm thinking that, according to how it was hooked up before, that 2 neg leads would connect to the tab, and the pos of the 3rd would also connect to the tab, which would be shoved up and ground to the can, and still isolated from the chassis due to the cardboard ring.
Is this right?
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 72
City: Linn Creek, MO
All three negatives connect to the can, which is connected to the center tap of the high voltage winding. The positive ends connect one to each end of the choke and one to the chassis ground.
M R Radios C M Tubes
(This post was last modified: 03-29-2020, 09:50 AM by Steve Davis.)
Threads: 91
City: Jonesboro
I got the Filter caps resolved, and the radio is up and running.
Now I'm troubleshooting a couple things. A dirty volume control, and a faulty tuning mechanism.
Someone has had their hands on it before me.
Can anyone tell me on this Code 125 how the dial mechanism is supposed to work? The current routing of the cord is not working, and, frankly, doesn't look correct.
I'm wondering, after examining it, if it's supposed to have a tension dial cord on the "back" mechanism, and a dial belt on the "front" part of the mechanism.
If anyone has any pictures, diagrams, whatever that they could post or link me to, I'd be most grateful.
Here's 2 pics before I took it apart.
[Image: https://live.staticflickr.com/65535/4972...d13e_k.jpg]
[Image: https://live.staticflickr.com/65535/4972...6484_k.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 569
#91 has to be isolated from chassis if used as astandalo e can, as uts + is to the chassis,and the - which is the can is not and so shouldn't touch it.
Threads: 214
City: Seattle
State, Province, Country: WA
Hi Jeff - here are a few photos I found of my Code 125 chassis dial string. I hope they help!
Threads: 91
City: Jonesboro
Thanks Nathan. How many turns are on the lower left shaft? (Shaft behind the tuning knob) I had a smaller cord than what was on there, and there didn’t seem to be enough ’drag’ to get it to work.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 214
City: Seattle
Threads: 91
City: Jonesboro
I got the tuning mechanism sorted out. It still slipped, so I brushed some liquid Plasti Dip in the groove of the shaft behind the tuning knob. That did the trick of giving the cord some grip.
I also cleaned the volume control.
Next is to align it. Although it seems to be pretty good at this point.
Here’s a short video of sampling the AM dial. The Big Band Music is from my AM transmitter.
[Video: https://youtu.be/CM_7LH1pu9U]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 416
City: Boston
Sounds swell! Fine work. Paul.
Threads: 91
City: Jonesboro
Continuing on the restoration.
The volume pot was iffy. I took it apart, and discovered cracks in the wiper surface. So I ordered and just replaced the control.
I did an alignment, but I’m getting this weird oscillating between 14-16 MHz on the upper SW band.
Is there something I should look for, like an out of tolerance resistor or mica cap that might need replacing?
Here’s a video demonstrating it.
[Video: https://youtu.be/KUoqk_wO4aI]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 15
City: Weymouth Ma
For the dial stringing I might suggest clicking on the portal tab at the top left of the page and then on the lower right click on the Philco Library. Then if you look at the dial stringing information for model 14, 17 etc ( a whole bunch of part #s)I think you will find what you need. Although it is not mentioned or I missed it.The dial stringing for the model 16 code 125 is I think the same as the model 17. If memory serves me correctly the original dial string was 0.060" or 0.065" and something up to .090" has been discussed. If your dial string is not thick enough you will have slipping no matter how tight you make it or how strong the spring is. I found this out on a model 17 which is pretty much a model 16 with less shortwave coverage.
GL,
Henry
Threads: 91
City: Jonesboro
Any ideas or tips on the odd signal on the SW band?
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 268
Posted on your FB a few days ago some other things. Do you have a shield on the 76 tube?
Threads: 91
City: Jonesboro
Yes.
I tried swapping the 76 tube as well with a known good one. Same result.
Blessings,
Jeff W.
Jonesboro, Arkansas
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
There are currently 2641 online users. [Complete List] » 1 Member(s) | 2640 Guest(s)
