Next Project - 37-116
Pretty much stuck at home so I have to start another project to maintain sanity.  I finished the cabinet many weeks ago so now to start the electronic restoration.  I purchased the cabinet with speaker and "acoustic clarifiers" last year.  With Ron's help, I found a 37-116 chassis as well.  So, time to make the radio work and mate the two together.  The 37-116 cabinet is on the left.  It's younger sibling, the 38-116 is now complete and playing beautifully.
That chassis should keep you busy for awhile. Beautiful work on the cabinets!
Those cabinets are beautiful, did you do those yourself?
Thank you, John. Yes, a lot of spraying and sanding and spraying and sanding.
Terrific job on those cabinets indeed. Do you have spray equipment or use rattle cans? I have a 37-116 that someone kept a house plant on the top. There is water damage, but I doubt I would ever find a perfect match for the toner so I’m looking at refinishing the whole cabinet instead of just the top. I don’t relish doing that with rattle cans on such a big cabinet!
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
+1 to Mike, John and Ron.   Gorgeous!   Icon_thumbup
Great job on the cabinets. It is a lot of work to get them to look that good.
Ron, I have an HVLP system that I've had for years for other purposes (painting my airplane). Works well. I've taken to mixing my own toners as I can't get an even job with a rattle can. Just not very good at it!
Super! This is what I expect they should look like.
Thanks guys. I have a 37-116 that is in excellent original finish, so I had an example to work from.
Decided to get the RF chassis out of the way first.  The Police Band oscillator had to be rewound, as expected.  I hope it works!  This chassis is fairly rusty so I decided to paint.  I replaced all resistors and re-stuffed all of the caps.  There are 2 caps between switch wafers that are a real pain. I had to remove the coil/switch assembly in the antenna and RF sections from their associated mounting plate to get at the solder connections.
Are you using a metallic paint on the chassis?
Rod
Yes. It's metallic aluminum, Rustoleum Painters Choice 2X with primer. Not a perfect match to a clean, later model chassis, but it's okay. I will sometimes use it to cover removed rust spots for protection. It blends quite well with the cleaned, original, plated metal. I kind of like the clean look of a painted chassis but would never paint a well preserved chassis. I'm concerned that a rusty chassis with the rust removed will rust quickly if not protected. Some have used clear, others have used a protectant like BoShield, and others paint.
Thanks for the reply on the spray system. On my 37-116 I had to rewind the band #2 oscillator coil also. Took me 3 tries, ugh, but finally got it working. It’s still not right because I think the inductance is probably off. When I did an alignment, I can get the low end and the high end pretty decent with the associated trimmers, but sensitivity falls way off in the middle of the band. I don’t think the oscillator is tracking properly. This was the first coil I ever tried to rewind. Since there isn’t much on this band anyway, I’m leaving well enough alone. Not trying a fourth time. I didn’t dismantle my tuner as much as yours, so to get at those hard to reach caps, I made a long replacement tip for my soldering gun out of 12 gauge house wire. I saw that tip on the phorum years ago. It was a real pita to get in there but doable. Good  luck with yours, looking great so far!
Ron
Thank you, Ron! This is the second one of these I've done so I the advantage of a little experience. This one will, no doubt, go faster as a result.
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 4023 online users. [Complete List]
» 2 Member(s) | 4021 Guest(s)
