Type of veneer
I know I knew at one time, but I forgot what type of veneer this is. Zebra wood?
[Image: https://i.imgur.com/cLcPK1o.jpg]
Mahogany - I believe.
I'm talking about the specific pattern, but I do believe it might be a type of walnut. Or, like I mentioned, zebra wood. I can't seem to find anything with a pattern like that.
It's hard to tell from a small photo but, I'll have to agree with Russ. I think it is a quarter cut mahogany.
M R Radios   C M Tubes
Here's another pic.
[Image: https://i.imgur.com/9xTNO1s.png]
Oriental Wood, sometimes called Australian walnut.
Yep! You got it. Pattern looks the same. And Joe at VeneerSupplies said it's just quarter sawn, but he didn't have any.
PM sent.
