Type of veneer
I know I knew at one time, but I forgot what type of veneer this is. Zebra wood?
[Image: https://i.imgur.com/cLcPK1o.jpg]
Mahogany - I believe.
I'm talking about the specific pattern, but I do believe it might be a type of walnut. Or, like I mentioned, zebra wood. I can't seem to find anything with a pattern like that.
It's hard to tell from a small photo but, I'll have to agree with Russ. I think it is a quarter cut mahogany.
M R Radios   C M Tubes
Here's another pic.
[Image: https://i.imgur.com/9xTNO1s.png]
Oriental Wood, sometimes called Australian walnut.
Yep! You got it. Pattern looks the same. And Joe at VeneerSupplies said it's just quarter sawn, but he didn't have any.
PM sent.
There are currently 9656 online users. [Complete List]
» 1 Member(s) | 9655 Guest(s)
