Adding a Magic Eye
Does anyone have an idea on how to install a Magic Eye tube in my 41-300? I would like to install a Magic Eye tube in a small project box to set on top of the cabinet, rather than make any changes to the existing radio.
In general, you would need to bring 6.3 VAC filament, plate voltage, and AVC voltage to the Magic Eye tube. You can pick off the AVC (Automatic Volume Control) voltage from the 2.2 meg ohm resistor connected to the 7C6 diodes. The 2.2 meg resistor feeds AVC voltage to the grid of the 7B7 first IF tube (via the secondary winding of the first IF transformer)
Exact biasing of the Eye tube would require a little experimentation with how it reacts to the AVC voltage levels. I'm sure a peek at schematics of sets using an Eye tube will give a good starting point. Take a look at http://home.pacbell.net/philbert/tuning_eye/avc&eye.htm for a discussion on biasing Eye tubes.
Thanks. I really don't need to do this, but I have fond memories of watching my Grandfather's old, what I believe was a Zenith, and thinking that it was indeed magic. I'll plug it in as an external so it will be completely removable should I eventually get tired of it.
Henry
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7427 online users. [Complete List]
» 2 Member(s) | 7425 Guest(s)
