Threads: 55
City: Lexington, KY
Mike L,
Is your second hand just missing or does your clock not have a place for one?
Threads: 44
City: Roseville, MN
LOL, you guys are starting to sound like Abbott and Costello's Who's on First.
Threads: 569
>> Is you second hand just missing?
As long as the first is still there. Otherwise it is hard indeed.
Threads: 9
City: Springville NY
State, Province, Country: NY
As near as I can tell it never had a second hand. FWIW, I'll post a photo after work tonight.
Mike
Threads: 9
Actually, I started a thread on mine with photos a while ago. Really have'nt had any time to work on it.
https://www.philcoradio.com/phorum/showt...ther+clock
Mike
Threads: 569
Mike
Yes, I remember the thread.
Well...now is as good a time as any.
My USPS boxes should arrive soon, so I will ship my clock for the motor to be rebuilt.
Threads: 42
City: Jeffersonville
State, Province, Country: PA
Hey Mike,
Mine does have a second hand on it.
Threads: 569
So I tried the split pins.
Though the diameter was exactly right, stainless against wood provides very little retaining force.
So I used a wedge tool to split the pin further.
The pin then has to be aligned and compressed a bit to start getting into the hole. Or maybe the end of it ground to form a chamfer. Or maybe the wooden hole slightly countersunk at the top. Just to start guiding the wider split pin.
The result is acceptable.
At the end, I think it might be a better choice for this particular goal than the one from the Renovated Radios, the reason being, the latter, if does not provide retaining action, cannot be split anymore being plastic, whereas the metal one can.
Threads: 569
Today Mike from Norkro told me my clock is working fine and is being tested.
He said it was gunked up oil, no rewind was necessary.
When I asked why then I was able to rotate the first sprocket and consequently the motor shaft, he explained that these motors are very weak and cannot handle even moderate gunking.
OK, so now I know that.
He will send it back to me soon.
The total with shipping came to exactly $55. If I were savvy enough and chose to take the gear off and ship the motor only, it would then be $30. But... .I thought, might as well service the whole clock.
Threads: 569
The clock came back this morning.
It is being quarantined for 4hrs in the garage, and then will go to the shop.
Threads: 569
It works.
Haven't checked the timekeeping yet.
The trippler does not take the new plugs so I have to plug the cords separately.
I also have to come up with a fuse box, the wire nuts inside that can do not make me confident.
Threads: 569
So...
What I am pondering is....
The clock is working well.
So does the radio.
I am not in the habit of keeping my radios plugged in, as I do not want to drill holes and install fuses, and the radio without a fuse is a fire hazard.
So, I resort to plugging them into power strip that are off. If I want to listen to a radio, I turn the respective strip on.
However this done to a clock means the clock being, well.....useless.
This is why I thought plugging the radio and the clock to a fused strip. Like 1.5A - 2A, fast action, should be adequate.
I cannot seem to find anything like it.
I can make one myself, taking a 2-outlet metal box, placing two outlets in it, putting a fuseholder...well, 2 fuseholders, to protect the radio and the clock separately.
I have to exclude the original tripler mount on the wall from the picture. It does not accept modern polarized plugs.
But before I make a project out of it, I would like to make sure there is no off-the-shelf solution.
The fact that I haven't found one does not mean it does not exist.
Anyone knows of something of that sort?
Like a fused tripple plug adapter? Or anything suitable?
Threads: 49
City: Allendale, MI
Morzh, I'll send you a fused Elmenco plug as used on the 37-116 if you wish.
Threads: 569
Rfeenstra
This one, right?
https://www.ebay.com/i/372279994420?chn=...gLwMfD_BwE
If you have an extra one, I'd be much obliged.
I haven't used those...do they house a changeable fuse?
Threads: 569
Someone is selling a box of 10 on eBay.
Want $75 plus 15 shipped.
Is this excessive?
Should I offer so ething (guy accepts offers)?
Users browsing this thread: 34 Guest(s)
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
