Zenith Schematics resource like Philcos
I'm preparing for my first Zenith renovation.  On old Philcos, I would send $7 to Chuck at the Philco Repair Bench and get a great 11X17 schematic plus service manual pages.  Does anyone provide such a service for Zenith?  I just received an 8x10 I paid for from another source which is not much better than the one I got online and the detailed info is hard to read.
Thanks!
Mark
Unfortunately, there isn't that I know of. You have to take what you can find at www.nostalgiaair.org or www.radiomuseum.org. Those are my two go-to sources for non-Philco sets. When I print them out, I enlarge to 200 % and tape the 4 pages together to make a nice big schematic.
Hi Mark
You can try looking here. The quality seems pretty good. If you have a printer, you can print them or I think they will print and mail them for $8.
https://www.tubesandmore.com/schematics
I bought a CD from EBAY several years ago with all of the Rider's and Beitman's schematics. They were very good but unfortunately I can't find the seller.
I see this guy selling them. I can't attest to the quality, but it might be a good option too.
https://www.ebay.com/itm/Tube-Radio-Sche...0311187040
Looks like he sells printed copies for individual radios too. He says it's 13"x19" for $7.50 with shipping...
https://www.ebay.com/itm/Beitmans-Riders...2316312964
I usually print my own and will blow up and tape together for enlargements if I need to.
Greg O.
Whitehall, PA
I have the set from KE3GK and they are hi resolution scans. Very readable. I usually blow up the schematics and tape together as well. The hi res pdf's are good enough to do that.
Thanks for the help! Much appreciated.
I have ordered a set from KE3GK.
Mark
Philco 91 Tuning Condenser
