37-650 buzzing
One end of resistor (46) connects to the control grid of one of the 6F6G tubes, which is pin 5, not pin 4. We'll get to the other end of (46) shortly.
Resistor (52) is connected from the screen grid of one 6F6G (pin 4) to the screen grid of the other 6F6G (also pin 4).
Condenser (47) connects from the control grid of one 6F6G (pin 5) to the screen grid (pin 4) of the other 6F6G.
Resistor (53) connects from the control grid of one 6F6G tube (pin 5, same pin that one end of condenser (47) is connected to) to the other end of resistor (46), and on to B- in the power supply circuit.
Double-check your connections.
You can't always go by a pictorial, they can be wrong. The placement of (46) in the 37-650 under-chassis pictorial looks incorrect to me.
Rely on the schematic instead of the pictorial.
There is a handy website which will give you the pinouts of thousands of tubes, along with their specifications.
http://www.nj7p.org/Tube.php
Using this resource, you can compare these pinouts to the schematic drawing for a clearer understanding of what is going on inside the radio.
Yes!!! Switched the resistors per your direction and BINGO...the radio works!! Ron...you've been a hugh help...I really appreciate you sticking with me on this...
Thanks much...Bill
Congratulations! Another one fixed... Icon_biggrin
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7224 online users. [Complete List]
» 4 Member(s) | 7220 Guest(s)
AvatarAvatarAvatarAvatar
