Philco 76-1134 Antenna Coupler (three prong)
Threads: 43
City: Mission Viejo, CA
I just bought a Philco 76-1134 antenna coupler for my Philco 41-250, and have the schematic which someone else drew.
This was first discussed (at least with me involved) in this thread where there are photos of the unit which Ron posted:
http://philcoradio.com/phorum/showthread.php?tid=1472
[Image: http://i269.photobucket.com/albums/jj77/...0001-3.jpg]
Stephen
Thanks very much for sharing this! This should be very helpful to everyone.
Now we know how Philco intended for a longwire to be connected to those 1941 and 1942 sets which have this jack.
With this information, a person could make his or her own coupler.
Threads: 43
I just looked at the one I bought, which had been carefully cut throught the solder which joins the bottom to the can. The Mica capacitors color dots are black-blue-black, with an orange dot below those three, indicating a value of 6pF +/- 3%
Threads: 17
City: Yorkville IL
I know I'm late coming in on this but, are there any markings on the "coil" listed in the schematic?
Thanks Glenn
Happily back in Illinois..not.
Threads: 43
I can't see any marks, but was able to emasure it - 0.292 mH
Threads: 23
I don't know if I am missing something, but the schematic does not make sense to me. In the distance position the antenna is connected to the receiver through the resistor, cap, and inductor network. In the local position the antenna is not connected to anything, and only the network is connected to the receiver. I would think the antenna should be connected in some way in either switch position.
Harv
Harv
Harv
In the "local" position, the radio would be operating only on its loop antenna, so there would be no need for a connection to an external antenna when the switch is in the "local" position.
Threads: 23
That makes sense Ron. Now I'm trying to figure out why Philco used that network when the external antenna was connected. I'm a curious person.
Harv
Harv
Threads: 23
Using the information in these messages, I built an external antenna unit for my 41-250. It improves the S/W reception considerably, as would be expected, and also helps a little on the BC band. Since my external antenna is only 40 feet long, it may be too short to provide a significant improvement on the BC band.
Harv
Harv
Threads: 13
City: Bristol, RI
Hi all,
I would like to build one of these couplers. But a few questions:
First, what is that coil on the schematic? An inductor? If so would anybody tell me exactly what I would need to buy? Not sure what it is, values etc.
Also, what's the value of the mica?
I am very interested in building one of these, and any help I receive would be much appreciated. Thank you,
Ted
See posts #3 and #5 above, where Stephen Masek found the mica cap to be 6 pF and measured the coil at 0.292 mH.
Threads: 13
City: Bristol, RI
Thanks Ron. My apologies for overlooking the mica value. But I did see the .29 mh coil reference; my problem is of more of a practical nature. Where would I find something like this? Googling .3 coil offers no help, so I've no idea where to go from here and was hoping you all could point me in the right direction. Thank you!
Threads: 40
City: Las Vegas, NV
Threads: 13
City: Bristol, RI
Thank you!
Mouser is almost like an inside joke to me. I have gone on that site a handful of times looking for a particular value resistor, cap, etc., but usually leave frustrated. Their search system is labyrinthine!
Threads: 10
City: Columbia, SC
That isn't the right inductor, is it? This calls for .3uH, the linked one is 300uH.
Philco 91 Tuning Condenser
I thought you meant the actual dial....there are rivets.morzh — 08:42 PM |
This is what I meant.
I would start from touching Test Point 12 on the sch.
See if you hear hum.morzh — 08:37 PM |
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
There are currently 8966 online users. [Complete List] » 2 Member(s) | 8964 Guest(s)
