Silvertone 1671 schematic/labels
I am restoring a Silvertone 1671 table radio and no matter where I search, free or for cost, I cannot find schematic/alignment info for this set. The closest I came is model 1571/1171, chassis 101.610-1. My chassis is 101-610 but there are definite differences.
This set uses a voltage doubler AC rectification scheme that appears a bit different from the 1571, as well as the tone control being a switch in the 1571 vs. a pot in the 1671. Does anyone have a schematic or know where I can obtain one?
Also the three labels on the back of the chassis are virtually disintegrated and wonder if anyone who has a similar set could take some clear photos so I can try to reproduce them. One is a vertical label on the IF can and the other two are on the right side of the rear panel.
Steve D
http://demandred.dyndns.org/540i/gallery/Antique-Radios
There are currently 8768 online users. [Complete List]
» 3 Member(s) | 8765 Guest(s)
