Sleuths unite!
What model is this Philco chassis?
Icon_smile
Ok I'll start the ball rolling I think it's a 620 from 1936.
Could use a 6A7,75, 80, and a 42 tube.
Kirk,
 I agree it looks like a model 620.
                                   Henry
Good morning Kirk! NEO6425 posted several photos of a 620 in his thread in Philco Electronic Restoration section of the forum. I agree with Terry and Henry. You've got a 620 on your hands there! Take care and BE HEALTHY! Gary
Thanks all!
I knew one of my chassis was a 620 but they are all on the shelves unmarked, lol... Not to figure out what the other one is....
Icon_smile
https://philcoradio.com/phorum/showthread.php?tid=17820
Philco 91 Tuning Condenser
