1946 Gilfillan Bros. Model 56B on YouTube
I have uploaded my video on a 1946 Gilfillan Model 56B.
The link below is for anyone interested.
https://www.youtube.com/watch?v=QgQlQxkY1hE
Nice save Buzz and another great video.... thanks!
There are currently 10535 online users. [Complete List]
» 3 Member(s) | 10532 Guest(s)
