Crosley Radio Model ID
Does anyone know the model number of this Crosley?
[attachment=22483]
That would be a 1940 26 BB
Thank you, thank you. Really appreciate it.
Rod
Philco 91 Tuning Condenser
There are currently 9859 online users. [Complete List]
» 1 Member(s) | 9858 Guest(s)
