Rogers 10-85 cabinet all done
I like these Rogers radios,especially some of the cabinets.
 I picked this one up last fall and during the winter I did the chassis,
and replaced the top veneer.
 Now I finally got the cabinet done.
 Dan in Calgary
   Living in Calgary Alberta
Dan,
It looks great! Probably better in person.
Henry
Do you have the signal strength indicator working? It is an interesting circuit.
I suppose I am like a lot of other guys on these forums. I have not have any training in radio repair , or electronics.
So I don't understand a whole lot of the in and outs of how everything works. So to answer your question,
I did not know that the radio had a signal strength indicator. Sorry about that.
I guess I just replace the caps,check the tubes,and resistors ,clean the pots, and align the radio.
When it works OK after that I basically leave it alone.
It is my hobby , and I do enjoy it , but I am learning more about radios every day, and I hope it keeps me young.
I did enjoy looking at your site very much
Thanks
Dan in Calgary
There is a small light bulb in the dial scale that is tied to a grid on one of the IF tubes. As the signal changes, this bulb glows brighter. The reason that I asked is because it is hard to find a suitable bulb. I used one of the very small "grain of wheat" bulbs.  - - going from memory - - It is easy to miss this function altogether.
Now I unde5stand what you mean by a ''signal strength indicator''
 I guess I just call it a tuning light,   On my Rogers 10-12 There are two of them, and on my Rogers 6R932 there is one in the very center if the cabinet.
   I also have one in my DeForest Crosley 'Buckingham, and some of the tombstone models have them also.
 It took me quite a while to find the right bulb,but once I did  I ordered 20 of them, because I am always running into Rogers radios.
  The biggest thing about the bulbs,   [I found ] was the amps had to be just right
  The bulbs that do the job are   #1448.
 Dan in Calagary
The tuning light indicator works good on this one, and I finally got it all back together.
   Dan in Calgary
Philco 91 Tuning Condenser
