Parmak Farm Radio
https://www.russoldradios.com/blog/back-...farm-radio
Not too many of those around. Beautiful restoration Russ Icon_thumbup
thanks.
No, like I mentioned the ID on RM is kinda' messed up, using the model names "1937, Deluxe, 525" and a bunch of other combinations, all of which relate to the radio - in the correct order.
Somewhere on the site I have a picture of its big brother, a 735, as I recall. A truly impressive "farm radio". I think it is in the "rare & unusual" tab.
Another wonderful restoration Russ!!
Icon_clap Icon_clap Icon_clap
Nice set, sounds swell.
Great looking set.
Thanks guys.
I am about a day away from buffing out the 5-F-134 cabinet. This is the 2nd farm radio - the one that needed to have the chassis replated.
Since I was doing one chassis, I decided to replat a 5-S-127 chassis as well. On it the variable cap and IF transformer covers were done as well. I had mentioned zinc plating previously. This chassis will also fit in the same Zenith cabinet.
I will add it to the blog asap.
Do you have pics of the re-plated chassis? Perhaps I missed it in your blog.
It will still be a few days before I have the Zenith reassembled. I will post pictures of the process then. The zinc plating was pretty easy and inexpensive.
Picture: from left to right -
As found
Cleaned up (some base metal exposed)
Replated
The picture was originally vertically oriented making the can on the right appear larger. In the original orientation it was closer - so appears larger.
Nice. looking forward to seeing the whole chassis after re-plating. When I clean up a rusty chassis with a lot of base metal showing, I paint, but would like to re-plate if it looks closer to original. Extra work as the sockets need to be removed. Although, I'm used to that with the Scotts!
Philco 91 Tuning Condenser
There are currently 9407 online users. [Complete List]
» 1 Member(s) | 9406 Guest(s)
