Custom 1936 model 645
Last year, a local friend was cleaning out their garage, and gave me a couple chassis. One is a 645 rescued from a crumbling 645 console.
I have no need for more consoles.  Icon_crazy
So I thought it might be a fun challenge to come up with and build my own tabletop tombstone. I like the shouldered tombstones.
I also like the grille cutout of the 650L.
So I cobbled these together in Photoshop.
Which do you all like best?
I recently saw a non Philco table top with the speaker on the bottom, and thought it was interesting. Hence the different design.
If I do move forward, it would drive some purists crazy, and possibly some historian crazy in 50 years.  Icon_lol
[Image: https://live.staticflickr.com/65535/5009...a75b_h.jpg]
[Image: https://live.staticflickr.com/65535/5009...db96_h.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Harp on top.
From a practical point radio on the bottom speaker on top makes more sense. Easier to tune and see dial when it's placed on a table. But I think I like it the other way around (I'm lisdexsic).
Thought you were Italian. Icon_lol
Speaker on top looks more appropriate to me.
Philco 91 Tuning Condenser
