Threads: 2
City: Boca Raton
Does anyone currently make a label set for the Philco Model 70?
I understand the ones sold on Ebay a few years back were not very good.
I saw a old post about Chuck Paci making these but when I sent an email to cpaci1@verizon.net it came back as undeliverable.
Has anyone found a source currently producing these?
Ron
Threads: 214
City: Seattle
State, Province, Country: WA
Hi Ron,
It should be possible to create a label set from the Philco 370 chairside labels:
https://philcoradio.com/library/index.ph...ls/page/2/
The tube layout label is already correct. It should be possible to update the model label.
I'll do that and add to the library.
-Nathan
Threads: 2
City: Boca Raton
Threads: 562
Chuck Paci makes labels
Threads: 214
City: Seattle
Hi Ron,
Here's the patent label for model 70:
https://philcoradio.com/library/index.ph...ent-label/
Tube layout label:
https://philcoradio.com/library/index.ph...out-label/
See my thread on the model 370 labels for how to print it:
https://philcoradio.com/phorum/showthread.php?tid=14861
Do you have access to a laser printer? If not, PM me.
Good luck on the restoration!
Threads: 2
City: Boca Raton
Thank you Nathan. Yes I have a laser printer. Can you suggest a place to buy gold foil paper to print the label?
Threads: 214
City: Seattle
Oh sorry I thought it was mentioned in that original thread on the 370 labels. It's not.
The thread on 112 labels has it:
https://philcoradio.com/phorum/showthread.php?tid=17974
I bought gold paper from here:
https://www.paperpapers.com/stardream-me...k-dfs.html
Threads: 2
City: Boca Raton
Thanks Nathan the gold label looks fantastic. Anxious to make mine.
Thanks again.
Ron
Threads: 2
City: Boca Raton
I have this Philco Design Patent label on the arch of my Philco 70.
Is this available on the library? I would like to reproduce this for my other Philco cabinets.
Image(s)
Threads: 214
City: Seattle
Hi Ron,
No we don't have have that one yet. I've tried previously to recreate it but the result hasn't been satisfactory due to the lack of a good original scan or photo.
Do you have access to a flatbed scanner where you could scan what you have at 600dpi or higher? I'd be very happy to clean it up in Photoshop and add it to the Library.
A photo would be fine too if it's clear enough to read the small text under the Philco logo. To use a photo I'd also need the original dimensions.
Threads: 2
City: Boca Raton
I scanned my label with a flat bed scanner.
Size looks to be 1.75 by 1 inch.
Threads: 2
City: Boca Raton
Took another digital photo.
Image(s)
Threads: 214
City: Seattle
Thanks Ron!
For some reason the scan was at pretty low resolution. Generally scanner software will let you preview then select just a small area that you can scan at higher resolution.
The new photo is better. I'll give it a try with that.
Threads: 2
City: Boca Raton
Thank you. You are a great help to this hobby.
Threads: 214
City: Seattle
A Philco 70 / 90 design patent label is now available in the Philco Library:
Here are some photos of the end product printed on the same gold paper as the model label:
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM
Hello Peter,
Thank you for posting that !!
Sincerely Richardradiorich — 09:40 AM
Eico 232 VTVM Schematic
Try BAMA for a schematic.
Looks like a replacement power source for the D battery has been installed. The tube may be...Chas — 04:51 PM
There are currently 9041 online users. [Complete List ]» 1 Member(s) | 9040 Guest(s)
