Put new speaker to the philco model 90 and it does nothing
Hello friends:
I bought a philco model 20 radio about 8 years ago, but the wooden grille needs to be restored, but hey, the speaker was missing. stations with the speaker that I bought that can be to see if I have time and I will send you photos I would like if someone has the technical sheet.
A greeting.
https://philcoradio.com/library/download...l.%201.pdf
This is the schematic.
As for the speaker, I am not sure what you meant. Is it missing or do you have a new one?
This Google translation is very, very confused.
Hi,
https://philcoradio.com/library/index.ph.../speakers/
Go to page 4 and what you are looking for is called a "K" speaker.
This lists the specification of the original speaker. A replacement
output transformer would be 6000 ohms center tapped and
secondary to match the voice coil.
Hope this answers your question.
There are currently 9851 online users. [Complete List]
» 1 Member(s) | 9850 Guest(s)
