Label set for Philco 70
Nathan fantastic work as always.  Thank you.   Icon_thumbup
I did order the antique gold paper and the vendor shipped it very quickly and I received it in a few days.
I am anxious to print these labels.
Thanks again.
Ron
I picked up a Philco Model 71 Cathedral locally.  I was able to remove the tube shield label and scan it.
I do not see this label in the library.  I hope this helps the Phorum members.
Thank you for contributing this! Will get this added to the Library.
