Philco 46-1203 record player cover
Have a problem with the cover for the record player not opening all the way..
[Image: https://live.staticflickr.com/65535/5021...1ce7_c.jpg]
[Image: https://live.staticflickr.com/65535/5021...67cc_c.jpg]
Will not open past 3/4 way  do not want to force it  What am I doing wrong?
Skip
If you remove the two screws on the side bracket, open the lid all the way, and re-attach the side bracket with the pivot arms up instead of down, it should work.
Roger That It worked
Thanks
Skip
There are currently 8934 online users. [Complete List]
» 2 Member(s) | 8932 Guest(s)
