OLD BOGEN AMP PLEASE ID
Need ID on this Bogen Amp..  I cannot read the model number?
Maybe someone else Can?
Has 7 tubes 6F5,6F5,6C8,6F8,6L6,6L6 5X4
Pictures...
[Image: https://live.staticflickr.com/65535/5027...dee3_c.jpg]
[Image: https://live.staticflickr.com/65535/5027...5873_c.jpg]
[Image: https://live.staticflickr.com/65535/5027...96e2_c.jpg]
Thanks
Skip
Looked all over and this is the closest I could find. It has 10 tubes instead of seven.
There is also a DX 18 but tube line up also not a match.
https://www.radiomuseum.org/r/bogen_ampl...dx_30.html
Thanks
I did find (With help from other Forum) That the model D30 seems to match the tube lineup..Looks the same also..
He even sent me a schematic..
Skip
Neat! Reminds me I must start work on the duo of DB 130 amps and tuner lurking in our front room. They make a nice stereo pair Icon_smile
