90 Chassis fit a 70 Cabinet
Will a 90 chassis fit into a 70 cabinet? I wondered if they were the same size. I know the moldings on the bottom is different the point on the top of the arch is different. Thanks for any suggestions.
No such luck. A model 90 chassis won't fit in a model 70 cabinet. The 90 chassis is wider and deaper, about an inch each way.
M R Radios   C M Tubes
Thanks a million. I thought they were the same size.
Dave
There are currently 11137 online users. [Complete List]
» 2 Member(s) | 11135 Guest(s)
