Refinishing my 40-180 cabinet
Icon_biggrin  Thanks
That's an excellent job! It looks amazing with the low gloss lacquer top coat.
Tony
Thank you
Fred,
Just curious, did you use medium walnut for the entire cabinet or a combination of light walnut and medium walnut toner? I’ve read different things about this and am getting ready to refinish my 40-180, so want to make sure I do it right. Your 40-180 looks amazing by the way!
Vinny
Greensburg, IN
"We don't care what you do...just don't electrocute yourself or burn the house down."
-My Parents
I use a medium walnut dye based lacquer on the majority of the cabinet to show the grain. I use a dark walnut pigment based lacquer on the trim parts along the bottom and top edges where the wood grains don't really show. I mask off all but the trim parts and spray the dark walnut, then finish with the medium walnut after removing the masking.
Great thanks! I thought the base and midline trim parts are darker on mine too so wanted to double check before I order toner. Appreciate the reply, and again, nice job on your 40-180. Looks like new!
Vinny
Greensburg, IN
-My Parents
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 2612 online users. [Complete List]
» 2 Member(s) | 2610 Guest(s)
