Philco 640, finally done
[Image: http://i1194.photobucket.com/albums/aa37...011019.jpg]
The "white" on the columns is old dust mixed with oil from my polishing rag. Got all over the radio when I applied oil. Jeez...
Very Nice!!
CRAP!!!!! Looking at the photo I just realized that I put the grillecloth on UPSIDE DOWN !!!!!!!!!!! Icon_evil
The cabinet looks great!
I looked at it late last night before bedtime, and I didn't even notice the upside-down cloth...
There are currently 7106 online users. [Complete List]
» 1 Member(s) | 7105 Guest(s)
