Threads: 268
> it looks like the only way to adjust the 3 stages is to physically adjust the pulleys on each shaft for maximum signal.
That's it. A lot of the older trf set are set up that way. The ones that use #26 tubes or triodes may have a neutralization adjustment. Triode AK sets battery and early ac like the model 20 or 40 use a resistor in series w/the grid lead to prevent oscillation.
Threads: 49
City: Allendale, MI
I was able to repair the RF transformer. The break was right next to the terminal so not much of a problem. That allowed a MUCH greater sensitivity. by increasing the spring tension on the tuning capacitor shafts, they settled into a more centered travel giving stations all accross the dial.
This is the first non AGC radio I've played with and can see/hear that AGC was a tremendous improvement in the day! The Philco 96 TRF performs so much better than the AK 55.
Voltages are indeed much higher than they should be. Interestingly, several resistors had been changed a long time ago to higher values, perhaps to compensate for 60 cycle rather than 25. Not sure what I'm going to do as it will take a pretty good resistor to drop the line voltage. Since I'm not too impressed with its performance, I may just leave it for an occasional demonstration and keep it for show.
(This post was last modified: 12-25-2017, 11:42 PM by rfeenstra.)
Threads: 49
City: Allendale, MI
Threads: 268
Looking Great!!!!
I was never one for that strip down start from the ground up unless it was really really bad. When I was working it just took too much time and patience. Now that I'm retired it seems to be quite possible for me to do.
AVC is a big + on these older sets especially if you live in a city where there are some big guns transmitting. At night it's difficult to tune across the band without getting knocked off your chair by a powerful station.
I have a Philco 76 that I need to revisit. One of the 45 output tubes looses filament voltage (bad connection somewhere) but was toying with the idea of adding avc to it. Takes about 6 additional parts and have to reroute the volume control to the audio side of thing vs the ant.
One of these dayz...
(This post was last modified: 12-26-2017, 04:03 PM by Radioroslyn.)
Threads: 49
City: Allendale, MI
Thanks! I don't think it's worth adding AVC to this. I'll keep it "somewhat" original. Not fully since some mods had been done in the past and in playing with it, I've done further changes in the resistors to get bias and plate voltages a bit closer to the specs that I have. It's playing pretty good, though it seems a bit more distorted than other radios I've worked on and tone quality is less than stellar! I don't know if the universal interstage audio driver transformer has anything to do with that, but at least it works. I did calculate a series resistor for the line voltage and it's not as bad as I thought it might be, so I ordered one that will get the line voltage down to 105 vac or so. That seems to bring things down to a reasonable value. This radio will spend virtually all of its time sitting an a shelf looking pretty, and, as I said before, will only be turned on for a quick demo.
(This post was last modified: 12-26-2017, 05:46 PM by rfeenstra.)
Threads: 49
City: Allendale, MI
(This post was last modified: 11-09-2020, 09:58 PM by rfeenstra.)
Threads: 49
City: Allendale, MI
Threads: 271
City: Wilsonville
State, Province, Country: OR
Beautiful job!
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
