Philco Q-1710?
Hi there,
Recently purchased a Philco Q-1710. I’m trying to find out the year it was made. I’ve been trying to research online but I cannot find anything! Does anyone have any info that they could share about this model?
Thanks!
It helps a lot if you post a photo. I'm guessing this might be a 1960s radio.
Hi there! I am having difficulty including a photo in my post. From what I’ve found, other Q models came out in the 60’s so I was thinking the same. I will continue trying to add a photo.
Hi and welcome,
Your Q 1710 dates from 1967 and is listed in Sam's Photofact #913-7.
GL w/your project!
There are currently 8720 online users. [Complete List]
» 4 Member(s) | 8716 Guest(s)
AvatarAvatarAvatarAvatar
