Hammond Output Transformer Feedback Loop Workaround
Hello,
I'm replacing a Philco output transformer on a 39-40. I'm wondering how to work with the center tap connection on the primary or where the center tap used to be as well the feedback center tap on the secondary. I did read an earlier post about taking the high side of the secondary for the feedback. I was little uncertain about going about it. Can anyone help me out. Thanks.
The center tap on the primary side isn't going to do you any good for feedback as there is no audio present at that point just HV. The feedback loop will have to be connected to the secondary. I would just experiment with the different taps till you find something you like. I'm assuming that the transformer has a multi tap secondary. If it oscillates (squeals) reverse the connections. That's called positive regeneration what you want negative feedback or negative regeneration.
Good luck!
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7295 online users. [Complete List]
» 2 Member(s) | 7293 Guest(s)
