philco 60 -505
Been awhile ... but i found a nice 60- 505.
When i go to Nostalgia air ... would i go to model 60 for schematics?
Thanks for any info.
Yes, you will find it listed there under Model 60.
http://www.nostalgiaair.org/Resources/793/M0013793.htm
Don't forget, Model 60 underwent numerous changes during its nearly three year production run. All of the changes are documented here:
http://www.philcoradio.com/tech/60evol.htm
Your the man thanks a bunch. Icon_thumbup
Looked mine is the 60b 1936
Hi Denver
If this old gal gives you trouble double check the oscillator coil they can be a problem on this model.
Good luck w/it
Will probably wait till .. winter again to work on.
Get me another or two.. have some projects for cold season.
Order tubes ect. have everything ready.
Thanks for info. Icon_wink
The speaker table error?
Philco 70 antenna lead
