Circuit diagram- Philco S521B Radio
Smile
Hello, I'm new here.
I have a Philco Empire Automatic S521B Radio of GB (1938). I'd like to reactivate it, but I can't find on the internet a circuit diagram for this model. I have found a circuit diagram for Philco D521B but it isn't the same diagram which I need. I've attached photos of my radio. Is somebody able to help me?
Hope this info is helpful. Welcome to the Phorum.   https://www.radiomuseum.org/r/philco_emp...521_b.html
Hi and welcome,
Give this one a try:  https://www.radio-workshop.co.uk/service...20D521.pdf
The OP has stated that a D521 schematic is not the same as an S.521B schematic.
malkmm - I found a Philco (UK) Service Bulletin for model S.521. It may, or may not, be the same as an S.521B but maybe it will help? I will send you a private message (PM) on this subject.
Welcome to the Phorum!
It looks like the S521B might be a battery set, though it's also possible that someone may have swapped in an A.C chassis into the cabinet of the battery set.
Philco 91 Tuning Condenser
There are currently 9003 online users. [Complete List]
» 1 Member(s) | 9002 Guest(s)
