Where did Philco manufacture
Hi all,
Does anyone know where Philco radios were manufactured? I know the headquarters was in Philadelphia. Is that where they did all their manufacturing?
Any help would be appreciated.
Bill
Hi Bill,
You’ll probably be interested in the Philco history section of the Library if you haven’t seen that yet:
https://philcoradio.com/library/index.ph...o-history/
Radios sold in Canada were manufactured in Toronto, Ontario.
Philco 91 Tuning Condenser
There are currently 9486 online users. [Complete List]
» 1 Member(s) | 9485 Guest(s)
