I took the pledge, broke the pledge.....
Threads: 414
City: Boston
No more consoles......................well until a smallish one came along. Picked this up from a fellow radio club officer, really nice shape and restored. He needed more room, now I need more room. I like the dial and the 3 spars over the speaker reminiscent of those Arvin Rythym series, or am I high?
Eight tubes and a nice speaker, has a fine tuning pull option on tuner. So a lttle gift for Dad. Current console count in house is 2, 1 in garage.
https://www.flickr.com/photos/92577012@N...7282902762
Threads: 112
City: Medford OR (OR what?)
I'm working on a Scott 800-B right now. Nice cabinet, nice chrome, REALLY NICE radio and amp. It doesn't have the stock phono - Webcor 60. I have several choices but I don't think I want to limit this system to 78's only.
Oh - also, no place to put it.
Threads: 414
City: Boston
Where does it go?
Threads: 49
City: Allendale, MI
Russ, I have an 800B waiting in the wings. Fairly bad shape and no cabinet. Are you going to do a blog post on your progress? I'd like to see what your experience is! I may just want it to replace my 16A in the shop. I would like the quick tuning.
(This post was last modified: 12-12-2020, 09:16 PM by rfeenstra.)
Threads: 55
City: Lexington, KY
Nice Silvertone Paul
The grille bars do resemble those on the Arvin Rhythm series. Oh, I think you're among many here who have broken similar pledges
Threads: 103
City: Calgary, AB, CA
I like that console, especially the dial. The cabinet is also in very nice condition.
You must have more room because have more. Because I have 11 consoles in the house and 13 in the garage.
Dan in Calgary
Living in Calgary Alberta
(This post was last modified: 12-13-2020, 11:53 AM by Dan Walker.
Edit Reason: bad grammer
Threads: 414
City: Boston
Thanks Dan, I feel a bit better now. I can fit nine more in the house! ![Icon_smile Icon_smile](https://philcoradio.com/phorum/images/smilies/icon_smile.gif) .
Threads: 112
Paul, "where does it go?"
That is the question.
I am down to a couple of possibilities: Add on to the museum, a strong possibility after SARS CoV II goes away, or, selling it and a bunch of other radios/audio/boat anchors (likely in any scenario - after - - you know).
There is also the 29-tube Meissner console. It is much more rare. It looks good setting back by the tractor - -for a while. I do have a blog post coming up for this one and the Collins R390 and the Hammerlund SP600 and the Crosley Clipper and - -
Threads: 414
City: Boston
Oh yes where.....the hosue is a bit messy anyhow tree going up and all kinds things being moved about.
Really this one may be it.
This isn't ARF. You can say Coronavirus, COVID-19, Rona, etc. here. ![Icon_smile Icon_smile](https://philcoradio.com/phorum/images/smilies/icon_smile.gif) As long as it isn't politicized.
On-topic tidbit: I likewise took the pledge, then broke it when a friend brought over a Philco 87 and left it here.
https://ronsradios.com/2020/10/28/anothe...7-highboy/
Threads: 414
City: Boston
Now the Philco 45L I have in living room, not really console is it? Cuz then I got 3 in the house......is a high or lowboy really a console? I guess....... Paul.
Threads: 367
City: Dover, OH
Nice Silvertone there and the early version just like mine. The later version swapped a 6A8 for the 41 and 6D6 and dropped to 7 tubes. It also went to a more standard clicker type tone control and MG style tubes. My 1965 is the first 'big' console I ever bought and the Tombstone I got this year has the late style chassis in it.
Threads: 414
City: Boston
I believe the 6F6 is the output in the 1965. It does well given the speaker. I have an RCA table model with a 6F6 output that is a loud set.
The thing was built by Colonial. The Schematis sez feel free to order parts directly from Colonial odd as usually they always say Sears.
Threads: 367
City: Dover, OH
The push-pull 6F6s in my 1965 give plenty of sound. Same for the tombstone version, though smaller speaker. Actually the early tombstone version used the same speaker as the console.
Threads: 54
I lost count, but I would guess 15 at least.
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
Philco 91 Tuning Condenser
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
There are currently 8591 online users. [Complete List] » 3 Member(s) | 8588 Guest(s)
