replacing artificial leather on a 46-350 radio
has any one replaced the artificial leather and do you have any instructions on do it I need all the help i can get, thank you
I have patched the covering for this model but never had to replace it. I did a restoration on a Zenith TO (R600 I think) and discovered techniques for replacing the skin on Zenith web sites. I would imagine it's much the same. If you can get the old sections off in one piece, maybe with a little heat and a blade, you will have a pattern for each piece. Take lots of pictures.
The previous owner cut holes in one side so I removed the ends and all other leather. The ends came off in one piece but they seemed to have been formed around the corners no cut marks.
Donald, do you have a picture of your radio?
I have pictures on my phone but don't know how to download to your site I am not computer savy
How - to add pictures:
https://philcoradio.com/phorum/showthread.php?tid=29
Philco 91 Restore Code ??
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 6248 online users. [Complete List]
» 1 Member(s) | 6247 Guest(s)
