I now have a 15X
I got this today from a forum member. A Philco 15X from 1932. Restored electronically, and original cabinet finish. Plays wonderfully with excellent reception.  Better than other early 30's radios I own and have owned. The light on the front is a nice touch. I need to make room for it's final destination in the living room.
[Image: https://i.imgur.com/DW73R7o.jpg]
[Image: https://i.imgur.com/gGQZR7i.jpg]
[Image: https://i.imgur.com/CArtBte.jpg]
Nice going, you have discipline and a Knack for obtaining real neat sets.
I have a 15X too, by a differrent maker Icon_smile.
[Image: https://capeoldradio.com/cor_picts/RCA%2...553-P1.jpg]Paul
Great radio. Heart I dream of such and with great pleasure would buy the same.
Old Tube Radio Online Museum / Музей ретро радіо
https://www.youtube.com/user/RadioSvit?d...lymer=true
Sincerely Peter
З повагою Петро
Very nice!
I have one as well. It is in very good cosmetic condition; I haven't tackled the electrical restoration, because the power transformer and antenna coil are burned out. It was a lightning strike victim.
I'd like to find the version with the tambor doors.
A beautiful radio.
I wanted one like this. Eventually a year sgo I got 112X which looks very similar.
Remember to remove the lightbulb prior to removing chassis from cabinet - or - add step: go to store for new bulb.
Excellent!
Philco 91 Tuning Condenser
