41-608 off- on switch
Hi I’ve got a Philco 41-608 with a bad off on switch I think I’ve seen on the forum some one that had same problem and how they solved it but I don’t know how to find it, it’s a push switch like the station selectors. Any help would be appreciated.
Forrest.
It's called a latching switch. Some rebuild the old one and other replace it. I've replaced a few.
https://www.philcoradio.com/phorum/showt...php?tid=89
Might be handy to immortalize this post in the Library.
Thank you terry, that’s what I was looking for some one else who’s run into this problem and how they solved lt.
Forrest.
Had a 38-1 once. Think it was kind of rare.
Philco 91 Tuning Condenser
There are currently 8753 online users. [Complete List]
» 2 Member(s) | 8751 Guest(s)
