9-Tube Crosley Clipper
Seldom photographed in the wild:
https://www.russoldradios.com/blog/crosl...-from-1936
Russ
Very beautiful radio.
And a nude shot, too!
There are currently 10268 online users. [Complete List]
» 2 Member(s) | 10266 Guest(s)
