RCA phono motor question
Hello everyone,
I am working on Some RCA 1950s Phono's and looking at buying some that tape used on motor windings ?
As you can see in my Photo how I used heat shrink and spliced the wire but don't really care for it
I thought why not just remove the tape and do a better job and add new tape
Sincerely Rich
No photo here.
Here is that Photo everyone,
Are you asking about Friction Tape?
Hello Phlogiston,
is that what they call that special tape used on transformers and motors ?
Sincerely Rich
P.S. I did see this tape 3M 28 White Acetate Cloth Tape, 1" Width
Hello Everyone,
here is a photo of the tape i was looking at !
Friction tape is black cloth tape. That looks more like masking tape which would look pretty close.
Friction tape a staple of old style electric work, might be better than what was pictured. Used to use it on Hockey Stick blades.
Was a good supply at our house as dad worked at utility.
Hello Phlogiston,
Well 3M™ 28 is a printable white Acetate Cloth Tape with thermosetting rubber adhesive used for electrical insulating. This tape absorbs resins and varnishes and offers excellent conformability in coil wrapping applications.
It is electrically rated for 2500volts and 221 degrees F.
Cloth tape with funny smell was pretty popular in Russia.
+1 Russ
I've got some yellow masking tape that looks pretty close. But would probably burst into flames and burn your house to the ground![Image: https://philcoradio.com/phorum/images/sm...wisted.gif]
This is why I read the phorum Icon_smile)
Hello everyone,
thanks for all of your ideas .
sincerely Rich
There are currently 8747 online users. [Complete List]
» 3 Member(s) | 8744 Guest(s)
